Hello All,
Jorge seems to have come close to what I found the problem to be, or more correctly, what I did to eliminate the problem. It was a simple fix, since we merely removed the link between the earth ground lug and the negative terminal of the lab power supply. The only explanation we could come up with, was a ground loop was being created and it introduced noise when the power supply load was increased by activating an MCU output. We zeroed in on this issue by locating the section of code that caused the Debugger to Disconnect and eventually found a single statement. However, when we tried to connect a scope to monitor the BDM signals the problem stopped happening! That's why we ended up examining the power connections.
Regards,:smileyhappy:
Tom Michalski
