Compiler Settings/Preprocessor entries not correctly shown in IDE files
1,120件の閲覧回数
rhysdrummond
In my CodeWarrior projects (CW MCU 10.7, Windows) I define a few key items in Project Properties (specifically, C/C++ Build-Settings,Tool Settings/ARM GCC Assembler & C Compiler, Preprocessor).  I change the value of these #defines for different build configurations.
This actually works, and it produces the correct compile output. But what is shown in the IDE is not in sync with the build configuration I have selected. It seems to be stuck on one of the build configurations.
I've tried reloading, refreshing, rebuilding index, freshening all files, clean & rebuild, restarting CW, switching build configurations away and back, everything I can find- and the IDE content is still incorrect.
Can anyone please help me get the IDE settings in sync with the selected build configuration?
Thank you in advance.
2 返答(返信)
1,045件の閲覧回数
rhysdrummond
SOLVED.
Window-Preferences, C/C++, Indexer. Select "Use active build configuration" in section "Build configuration for the indexer".
Thank you me :smileyhappy:
1,045件の閲覧回数
rhysdrummond
Extra information: It seems to always use the first Build Configuration that was made. Not the first in the list- I reordered it in .cproject, same result. I deleted the configuration it was using, and suddenly it started showing the correct thing. I remade the configuration I deleted- and made it active- and the IDE still shows the settings from the previous build configuration!
Looks like a legit bug to me. Can anyone confirm this, or suggest a workaround?
