Compare CodeWarrior with IAR
1,243件の閲覧回数
danielchai
Senior Contributor I
I used the IAR EWARM before. And now I want to switch to CW, but when I test it, I find the CW sometimes works, sometimes does not.
Is it true IAR is much more stable than CW?
Thanks.
タグ(3)
799件の閲覧回数
pavel_sadek
Early versions of CW were less stable. However nowadays I would say stability is about the same for both, it depends what you are doing in there of course. :smileywink:
Pavel
800件の閲覧回数
pavel_sadek
Pavel
