Hi stevec, peg, bigmac et al
Following peg's note, maybe we should be asking what kind of timing tolerance can we expect from these devices in general over a reasonable range of temperature and
supply voltage? My hunch would be that 6% or so is not too bad, all things considered. Just don't try to build a stop watch
By the way stevec -- appreciate your threads. I seem to be having all the same problems you've had, but about a month AFTER you've had them -- so have learned
a lot from your conversations here!
