Code Warrior Project - The directory name is invalid error
1,424 次查看
donikuy
I am trying to build the eGUI project using Code warrior and I get the errors below:
Any idea why this would happen?
Kind Regards,
Ylber Doniku
1,187 次查看
Carlos_Mendoza
Hi Yiber,
Does the error gives more details about which directory is invalid? Could you attach the project so I can test it on my side?
Thanks in advance!
Carlos Mendoza
Technical Support Engineer
1,187 次查看
donikuy
Sorry I gave up on that project. Now trying to run another egui and get a lot of errors, which i think originate from the library paths. If you look at the picture below the libraries have a warning sign. Why do you think is that? I am assuming that stops my project building. I am using CW10.6 and MQX 4.1.
Ylber
1,187 次查看
Carlos_Mendoza
Hi Yiber,
I don't think that is what is causing the errors, the warning sign seems to be shown because the Libraries paths are relative paths. Could you post a screenshot of the errors you get? Maybe the compiler include paths are the ones that are incorrect?
Carlos Mendoza
