Cannot find jar file adding FXTH and NTM88 Starter Package
3,165 次查看
Markel
I am following the guide "UM11325 Installing and using CodeWarrior IDE for TPMS for FXTH87,
FXTH87E and NTM88". At CodeWarrior when I try to install either FXTH or NTM88 Starter package, I get an error "no software site found at jar file". How, do I solve this problem?
Markel
3,156 次查看
CarlosGarabito
Hi @Markel , the file or the directory that you are looking for does not exist, that's the problem with it, so you need to redirect the link where you have that file. by the way, we don't have support code warrior more, so i recomend to change to MCUXpresso.
Have a good day
4 回复数
2,938 次查看
Nadmi-Am
Hi @Markel , can you help me to write a main program to send a stored data with BLE ? the project is to access , print and send an IMU  stored data sent by nanosense ,using BLE
have you an example of code please ?
2,932 次查看
Markel
Hi Nadmi-Am,
I believe you can find resources for that in the internet,
Markel
3,153 次查看
Markel
After I extract the contents of the NTM88 Starter Package, the patch was found in the extracted folders and I was able to proceed following the guide.
Markel
3,157 次查看
CarlosGarabito
Have a good day
