Can a library created with GCC C be used in a project using Freescale C?
2,111 次查看
gorakk
Can a library created with CodeWarrior and GCC C be used in a project using CodWarrior and Freescale C?
We are evaluating a third-party library that compiles when using CodeWarrior 10.5 and the GCC C compiler but not with the Freescale C compiler.  Our existing application is using CodeWarrior 10.5 and the Freescale C compiler.
There are still issues with the library so before I put any more time into it - can this be successful?  Will a GCC C compiled library work with a Freescale C compiled project?
1,902 次查看
ZhangJennie
Hi Allen,
No. the lib made from Gcc compiler can not work for Fresscale ARM compiler.
this answer is for you. if it helps, please click on "correct answer " button. thanks!
Zhang Jun
1,902 次查看
ZhangJennie
Hi Allen,
what chip and CW version do you work with?
Zhang Jun
1,902 次查看
gorakk
We are using the MK61FN1M0VMJ12 and Codewarrior 10.5
Allen
1,903 次查看
ZhangJennie
Hi Allen,
Zhang Jun
