CW4.7 HCS12 - Special addition availble, but what about standard/pro?
ソリューションへジャンプ
2,947件の閲覧回数
RumJungle
I noted that there was a "special addition of CW4.7 for the HCS12 CPUs. When will 4.7 be available for standard/pro?
TIA
タグ(1)
1,528件の閲覧回数
CrasyCat
Specialist III
Hello
In fact if you want to use a V4.7 standard or professional edition all you need is:
  - download CodeWarrior for HC12 V4.7 special edition (or evaluation version)
  - Install the software
  - If you have a valid support contract, go to your licensing page
      ("My Freescale" -> "CodeWarrior Licensing")
  - Click on the button "License Options" next to your suite entitlement ID and get a new license for
     CodeWarrior HC12.
  - Copy the license you get in your V4.7 installation directory
That should be it.
CrasyCat
3 返答(返信)
1,529件の閲覧回数
CrasyCat
Specialist III
Hello
     CodeWarrior HC12.
That should be it.
CrasyCat
1,528件の閲覧回数
RumJungle
(Answer)
I did not try it because the site claimed that the tool had 32K limit. I suppose you cannot believe everything you see on the FS site.  I tried it w/my license and it functions very well in Vista with the Cyclone Pro.
Thanks! :smileyhappy:
1,528件の閲覧回数
CrasyCat
Specialist III
Hello
Well the good news with that is that we only have one installation layout.
The features are locked/unlocked with the content of the license file.
So installing an evaluation version and placing a permanent license in the installation directory will remove the time limitation :smileyhappy:
CrasyCat
