CW10.3 Build error
CW10.3 Build error
3,687 次查看
euge
I just installed CW10.3 and when I tried to build a project I received
the next error.
Errors occurred during the build.
Errors running builder 'CDT Builder' on project 'GT60-CW10_REG_V9.1'.
java.lang.NullPointerException.
Anyone have any suggestions.
Eugenio
8 回复数
2,684 次查看
BlackNight
Hi Eugenio,
hard to say what the problem is. Could you post your project?
Or does it happen if you create a project with the wizard too (without any modifications)?
2,684 次查看
jrarick
Hi Erich,
I have the same problem.  It is a rather large and proprietary project, so I would rather not post.  I was able to run in CW10.1 and downloaded the CW10.3 evaluation, and this error popped up.  Not sure what the issue would be.
2,684 次查看
BlackNight
Hi Jim,
ok, understood. But could you have a look into the .metadata\.log file inside your workspace? This one should show at the end a stack trace of the java exception. Maybe this gives a clue what the problem is?
2,684 次查看
nitinkothari
Hi Erich,
Any update about the error ?
Nik
2,684 次查看
trytohelp
Hi Dan,
I found some similar issue reported by other customers.
Most of the time it seems the problem was solved after to have created another workspace for his application.
To do that I recommend you to:
      - create a new workspace (another folder),
      - copy the project folder under this new workspace,
      - import it.
Hope this will help you.
Pascal
2,684 次查看
dan_quist
We are having the exact same problem. Been using 10.2 for the past year and we get this error when trying to build our 10.2 projects. The old MQX 3.8 projects build correctly, but our application projects do not.
Here is the log text.
!ENTRY org.eclipse.core.resources 4 2 2013-04-09 09:40:22.579
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.core.resources".
!STACK 0
  at com.freescale.core.ide.cdt.toolchain.CoreIDEMakefileGenerator.addTargets(CoreIDEMakefileGenerator.java:2149)
  at com.freescale.core.ide.cdt.toolchain.CoreIDEMakefileGenerator.populateTopMakefile(CoreIDEMakefileGenerator.java:1871)
  at com.freescale.core.ide.cdt.toolchain.CoreIDEMakefileGenerator.regenerateMakefiles(CoreIDEMakefileGenerator.java:1461)
  at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performMakefileGeneration(CommonBuilder.java:1804)
  at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.performPrebuildGeneration(CommonBuilder.java:1663)
  at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:1113)
  at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:723)
  at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:634)
  at org.eclipse.core.internal.events.BuildManager$3.run(BuildManager.java:821)
  at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
  at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:220)
  at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
  at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:385)
  at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:388)
  at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:444)
  at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:467)
  at org.eclipse.core.internal.resources.Workspace.buildInternal(Workspace.java:540)
  at org.eclipse.core.internal.resources.Workspace.build(Workspace.java:459)
  at org.eclipse.ui.actions.BuildAction$1.runInWorkspace(BuildAction.java:397)
  at org.eclipse.core.internal.resources.InternalWorkspaceJob.run(InternalWorkspaceJob.java:38)
  at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
!ENTRY org.eclipse.core.resources 4 75 2013-04-09 09:40:22.711
!MESSAGE Errors occurred during the build.
!SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 75 2013-04-09 09:40:22.711
!MESSAGE Errors running builder 'CDT Builder' on project 'Core_Kinetis'.
!STACK 0
2,684 次查看
jrarick
Will try.  Unfortunately I tried to update the CDT version.  Big mistake.  Trying to recover now.
!SESSION 2013-03-27 15:56:56.415 -----------------------------------------------
eclipse.buildId=I20070613-1755
java.version=1.6.0_15
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.ui 2 0 2013-03-27 15:57:42.950
!MESSAGE Warnings while parsing the commands from the 'org.eclipse.ui.commands' and 'org.eclipse.ui.actionDefinitions' extension points.
!SUBENTRY 1 org.eclipse.ui 2 0 2013-03-27 15:57:42.950
!MESSAGE Commands should really have a category: plug-in='com.freescale.core.debugger.ui.cdt', id='com.freescale.cdt.debug.cw.core.ui.rse.export.template', categoryId='com.freescale.categories.rse.freescale'
!ENTRY org.eclipse.osgi 2 1 2013-03-27 15:57:46.336
!MESSAGE NLS unused message: SWTWidgets_SearchCriteria in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: SWTWidgets_SearchText in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: SWTWidgets_SearchOptions in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: SWTWidgets_EraseText in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: DeferredLoadingContentManager_fetchingChildren in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: ObsoleteToolsNotifier_title in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: ObsoleteToolsNotifier_checkAgain in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: ObsoleteToolsNotifier_Problems_title in: com.freescale.core.ide.ui.messages
!MESSAGE NLS unused message: ObsoleteToolsNotifier_ObsoleteNotifierJob in: com.freescale.core.ide.ui.messages
!ENTRY com.freescale.processorexpert.core 1 0 2013-03-27 15:57:58.987
!MESSAGE Plugin com.freescale.processorexpert.core.service ProcessorExpertServiceProvider
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2013-03-27 15:57:59.268
!MESSAGE No repository found at file:/D:/workspace/MCU/MCU10.1_Release/Layout/eclipse/.eclipseextension.
!ENTRY org.eclipse.equinox.p2.metadata.repository 4 1000 2013-03-27 15:57:59.299
!MESSAGE No repository found at file:/D:/workspace/MCU/MCU10.1_Release/Layout/eclipse/configuration/org.eclipse.osgi/bundles/159/data/listener_1925729951/.
!SESSION 2013-03-27 16:01:06.526 -----------------------------------------------
!ENTRY org.eclipse.ui 2 0 2013-03-27 16:01:10.644
!SUBENTRY 1 org.eclipse.ui 2 0 2013-03-27 16:01:10.644
!ENTRY org.eclipse.osgi 2 1 2013-03-27 16:01:12.157
!ENTRY com.freescale.processorexpert.core 1 0 2013-03-27 16:01:14.544
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:02:35.893
!MESSAGE Indexed 'com.sandc.app.blinkled' (0 sources, 8 headers) in 2.31 sec: 0 declarations; 0 references; 8 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:02:41.088
!MESSAGE Indexed 'com.sandc.app.BMMHdwTest' (0 sources, 8 headers) in 0.00 sec: 0 declarations; 0 references; 8 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:02:45.790
!MESSAGE Indexed 'com.sandc.app.dnp2p' (0 sources, 8 headers) in 0.00 sec: 0 declarations; 0 references; 8 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:15.911
!MESSAGE Indexed 'com.sandc.app.dnpTest_byPK' (0 sources, 8 headers) in 0.00 sec: 0 declarations; 0 references; 8 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:20.810
!MESSAGE Indexed 'com.sandc.eos' (0 sources, 8 headers) in 0.00 sec: 0 declarations; 0 references; 8 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:22.948
!MESSAGE Indexed 'com.sandc.eos.update' (0 sources, 8 headers) in 0.02 sec: 0 declarations; 0 references; 8 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!MESSAGE Indexed 'com.sandc.timers' (0 sources, 8 headers) in 0.00 sec: 0 declarations; 0 references; 16 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:28.653
!MESSAGE Indexed 'com.sandc.eos.coldfire' (119 sources, 167 headers) in 4.26 sec: 10,065 declarations; 36,245 references; 47 unresolved inclusions; 1,179 syntax errors; 1,163 unresolved names (2.45%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:28.824
!MESSAGE Indexed 'com.sandc.assert' (1 sources, 15 headers) in 0.17 sec: 1,901 declarations; 1,431 references; 17 unresolved inclusions; 16 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:30.525
!MESSAGE Indexed 'com.sandc.app.dnpTest' (1 sources, 36 headers) in 1.70 sec: 4,336 declarations; 5,855 references; 22 unresolved inclusions; 0 syntax errors; 83 unresolved names (0.81%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:31.383
!MESSAGE Indexed 'com.sandc.app.SFConfig' (6 sources, 31 headers) in 0.86 sec: 119 declarations; 859 references; 8 unresolved inclusions; 0 syntax errors; 309 unresolved names (24.01%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:31.695
!MESSAGE Indexed 'com.sandc.dnp3' (5 sources, 37 headers) in 0.31 sec: 3,507 declarations; 5,042 references; 21 unresolved inclusions; 135 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.cdt.core 1 0 2013-03-27 16:03:31.741
!MESSAGE Indexed 'com.sandc.flash' (1 sources, 11 headers) in 0.05 sec: 979 declarations; 811 references; 17 unresolved inclusions; 0 syntax errors; 0 unresolved names (0.00%)
!ENTRY org.eclipse.core.resources 4 2 2013-03-27 16:04:30.918
!STACK 0
at com.freescale.core.ide.cdt.toolchain.ManagedBuildCoreIDEToolInfo.calculateOutputs(ManagedBuildCoreIDEToolInfo.java:707)
at com.freescale.core.ide.cdt.toolchain.CoreIDEMakefileGenerator$7.visit(CoreIDEMakefileGenerator.java:4712)
at org.eclipse.cdt.core.settings.model.util.PathSettingsContainer.doAccept(PathSettingsContainer.java:517)
at org.eclipse.cdt.core.settings.model.util.PathSettingsContainer.accept(PathSettingsContainer.java:513)
at com.freescale.core.ide.cdt.toolchain.CoreIDEMakefileGenerator.calculateToolInputsOutputs(CoreIDEMakefileGenerator.java:4616)
at com.freescale.core.ide.cdt.toolchain.CoreIDEMakefileGenerator.regenerateMakefiles(CoreIDEMakefileGenerator.java:1455)
at org.eclipse.cdt.managedbuilder.internal.core.CommonBuilder.build(CommonBuilder.java:726)
!ENTRY org.eclipse.core.resources 4 75 2013-03-27 16:04:31.164
!SUBENTRY 1 org.eclipse.cdt.managedbuilder.core 4 75 2013-03-27 16:04:31.164
!MESSAGE Errors running builder 'CDT Builder' on project 'com.sandc.eos.coldfire'.
!STACK 0
2,684 次查看
jrarick
Did you get a response?  I have the same issue.
