CW HC(S)08 v5.1 Special Edition and C++
1,804件の閲覧回数
Philip
The buyers guide for CW HC(S)08 v5.1 specifies a 16k C limit for the Special Edition.
Am I right that the SE does not support C++? (under PE New user module, I only see *.c, no *.cpp)
If so, what upgrade allows for C++ and what code size limit would apply?
Philip
タグ(1)
776件の閲覧回数
koubis
C++ is limited to 1Kbytes of code in the Special and the Standard Edition.
You need to upgrade to Professional Edition for unrestricted C++.
Lukas
2 返答(返信)
776件の閲覧回数
koubis
You can see more details at section 2.5.2 - 3
http://www.freescale.com/files/soft_dev_tools/doc/support_info/CWS-H08-PB.pdf
Lukas
777件の閲覧回数
koubis
Lukas
