I'm trying to use the Terminal via the virtual Serial Com Port for debugging my application on a k60f120m Kinetis Tower. But every time I try to establish a connection to the Port, I'm getting conncetion error
although there's no other application using the COM Port.
Sometimes the message changes to "there is no COM.. Port"
I managed to establish a conncetion once by chance. But after I closed the conncetion, I couldn't establish it again.
Any suggestions why it isn't working?
解決済! 解決策の投稿を見る。
What is saying the Device Manager for the Com port ?
This is listed under Ports (COM & LPT)
Do you use physical COM or a cable USB->COM
Did you tried to use another port (other USB)?
Pascal
Freescale Technical Support
Hello ,
Please check the COM port on the PC Device Manager ,
check whether is COM4 .
And please be sure on your PC , whether it already open one serial terminal , if yes , please first close it .
Hope it helps
Alice
COM port is corret and there is no other application using it.
Pascal
