CRC Calculation In Linker
1,962件の閲覧回数
tunayan
Dear Community members,
I have to find a way to calculate CRC of specific memory area in linker stage.
So I have developed a CAN bootloader and i want to compare the both CRCs before programming and run-time.
I am using MPC5644A Dev kit. And My IDE is CW 10.6
I tried to follow below  comments but, it is not proper with my mcu exactly.
CRC of Data section in Load Memory location
Thanks all.
2 返答(返信)
1,006件の閲覧回数
BlackNight
I'm using the SRecord tool for CRC calculation, see CRC Checksum Generation with ‘SRecord’ Tools for GNU and Eclipse | MCU on Eclipse
I hope this  helps,
Erich
1,006件の閲覧回数
TICS_Fiona
Hello Tuna
The Qorivva linker does not support this feature as DSC does.
But you can use the ‘crcgen.exe’ included in CodeWarrior v10.6.5 to generate a CRC in building.
For details, please see the section 5.1.7 in FAQ Guild:
C:\Freescale\CW MCU v10.6.4\MCU\Help\PDF\MCU_Power-Architecture_Compiler.pdf
But this solution can only get CRC in building. In run-time, user needs to add his own code to get CRC in application project.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
