Breakpoints across RESET's in True time simulator and real time debugger. Target - XEP100
ソリューションへジャンプ
1,411件の閲覧回数
sep2kor
Hello, I am using S12XEP100 target and i am executing some test cases over CAN. I issue target reset request over CAN. After RESET I is see that the breakpoints, that have been set, are disabled !!! (the target doesn't stop at the breakpoint) How to keep the breakpoints enabled across RESET's? Thanks in advance! ~Sandeep
タグ(1)
937件の閲覧回数
kef
Specialist I
Reset resets all hardware, including breakpoints hardware. This is what you observe - breakpoints are disabled after reset.
938件の閲覧回数
kef
Specialist I
