你好,买到一个新的 USB TAP Code Warrior CWH-UTP-ONCE-HE 要烧录BIN文件到芯片MC56F8013, 该下载哪个软件或附件,怎么操作请帮忙指导,感谢!
解決済! 解決策の投稿を見る。
Hello Yangchun
To program with a BIN file, please choose Eclipse CodeWarrior v10.6.4, and create a Target Task for flash programmer, or use the 'Flash File to Target' feature.
For details, please view the section <Debugger->Flash Programmer> in v10.x FAQ Guide:
C:\Freescale\CW MCU v10.6.4\MCU\Help\PDF\Microcontrollers_FAQ_Guide.pdf
CW10.6.4 can be downloaded from:
If you have S-record file, beside CodeWarrior v10.6.4, you can also choose 56800E Flash Programmer v1.2.
This tool is free and can be downloaded from our website in your CodeWarrior Suite. To find it, please
After installing, you also need o update CCS driver to supports USBTAP debugging on Windows 7.
For details, please refer to the link below:
https://community.freescale.com/docs/DOC-102607
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Hello Yangchun
Best Regards
Fiona Kuang
