where I can change the build order of different projects?
1,504 次查看
p_schroeder
I use MQX 4.2 for my application. When the MQX-projects and the project for my application are open, I get hundreds of errors when I build all. But when I close my application project, build then the MQX projects, open afterwards my application project again, the build works without errors. Is there a possibility to change the build order for the projects I have opened?
1,315 次查看
Carlos_Mendoza
Hi Patric,
In order to modify the build order of the projects in your workspace please follow these steps:
- Go to menu Window > Preferences
- Click on General > Workspace > Build Order
- Uncheck the option "Use default build order"
- Now you should be able to modify the build order of the projects, once you finish click on "Apply" then "OK"
Hope it helps!
Carlos Mendoza
Technical Support Engineer
1,316 次查看
Carlos_Mendoza
Hi Patric,
Hope it helps!
Carlos Mendoza
1,315 次查看
p_schroeder
Thanks a lot! It works now.
