when in debug mode, the arrow only in assemble code window
340件の閲覧回数
hansonlv
I use codewarrior5.1 . I copy a program from linda, and the program work well on her computer,but when i went into debug mode,some message appeared as"C:\Users\linda\Documents\ Projects\source\main.c could not found". I have been make the program, but why the information about linda appeared?
when i open the main.c ,there is no arrow in main.c, but i can see there is a arrow in assemble window. How can i do, anyone can give some advice, thank you all.
287件の閲覧回数
trytohelp
Do you have access to the main.c source file ?.
By default the .abs file contains the debug information and the paths of all source files using in an application.
However if the path changed or if the file is not found, only assembly code will appear.
How to solve it ?
Better is to have the full application or your PC and to re-build the project.
Then the path will be defined according to your PC project location.
Pascal
Freescale Technical Support
