how to output the build result to the log.txt through file redirection
2,023件の閲覧回数
kevinding
Using the Dos command "CmdIDE_PATH="C:\Program Files (x86)\Freescale\CWS12v5.1\bin\CmdIDE.exe" /r /b /c Project.mcp > log.txt" to automatically building the created project. but I cannot output put the such as "No error,<Code 0>" to the log.txt, How can I get it, thank you.
1,878件の閲覧回数
ZhangJennie
Hi Kevin
Attached video is for how to use file redirection command. FYI.
I use the demo code under CW5.1 install folder.
Jennie Zhang
