Thank you very much for your answer!
but , In your code, If I access the 0xC28000 address data, That's what I do
volatile unsigned long mybyte,test;
const unsigned long * __far myPpagePointer;
void main(void) {
volatile int i = 0;
myPpagePointer = &myBigArray_extra[0] ;
mybyte=*myPpagePointer;
myPpagePointer = &myBigArray[0] ;
for(;;)
mybyte=*myPpagePointer++;
i++;
test=(*(unsigned char *)(0xC28000));
However, data is not available, If I want to get the data from this address,
I want to retrieve data directly from the paging address
What should I do?
Have a great day!
