cwide.exe has  stopped working
1,076 次查看
yaakovbar-on
I use CodeWarrior version 10.8.3 on windows 8. I used it as simulator and has problemthat  when run the code with  trace And profile.
At the end of run appear a message "cwide.exe has  stopped working"
963 次查看
ZhangJennie
I ever had one customer met similar problem with CW.
It seems that this issue is caused by a installation problem. Or, conflicting with anti-virus would also cause such a problem.
so, may I propose a re-installing of the application from scratch? A repair install may not do the job.
Zhang Jun
