c++ code size limit
c++ code size limit
669 次查看
danbudd
Developing code for an S08/MC13213 uP on CodeWarrior v10.6, build 140329.
Created code in C without any problem.
       Summary of section sizes per section type:
       READ_ONLY (R):        31D1 (dec:    12753)
       READ_WRITE (R/W):      432 (dec:     1074)
       NO_INIT (N/I):          7E (dec:      126)
Compiling the C++ translation displays the following error:
    code size 3009 > 1024 bytes
What am I doing incorrectly and how do I fix this?
Dan
543 次查看
BlackNight
Hi Dan,
are you using C++? If so, without the professional edition, the C++ code size is limited to 1 KByte of code.
Erich
543 次查看
danbudd
Thank you.
544 次查看
BlackNight
Hi Dan,
Erich
