Hello Mayur,
I would suggest you follow FAQ 211 on the PEmicro website related to this issue. Eventually, the FAQ will prompt you download a patch for the CodeWarrior software located below the FAQ. The download specific to your issue is entitled “Patch for Eclipse CW10.x” and will require a PEmicro account in order to download successfully.
Once the patch is downloaded, there should be a ReadMe.txt file with instructions to follow in order to get your software working with newer PEmicro tools.
Let me know if you have any issues with this.
Steve
