Macro to determine EWL version
553件の閲覧回数
brianmitchell
There was an important bug fix in the Kinetis EWL implementation in Codewarrior 10.6 in the __copy_longs_aligned function.
I had previously implemented a workaround, but I would like to use the standard EWL function now.
Does anyone know of a macro or environment variable that I can use to determine the version of EWL implementation?
I checked C:\Freescale\CW MCU v10.x\MCU\ARM_GCC_Support\ewl\EWL_C\include\ewl_c_version.h but it did not change between the versions.
/* EWL 15.1 */
#define __EWL__ 0x00015001
Brian
タグ(2)
461件の閲覧回数
ZhangJennie
Hi Brian,
I just checked ewl_c_version.h. this definition:
is the same since CW10.3. I will check it with other team. WIll keep you posted.
Zhang Jun
