我们使用贵公司MPX53压力传感器做EMC测试时,传感器在频率为300-450MHZ,场强为10V/m的辐射下压力会急剧上升。我们采用了金属铜箔屏蔽,线缆上加磁环都没有任何改进。请问贵公司对这种情况有没有什么办法能够处理。
Please take a closer look at the attached AN1622 which provides details regarding EMC testing and results.
If you require a detailed analysis of your results, please describe in detail your test method, measurement technique and results.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct" or “Helpful”. Thank you.
我从您给的资料中看到这个EMC的测试环境布置应该是传导抗扰度测试吧?我们是在辐射抗扰度测试时出的问题。辐射抗扰度测试的环境布置如下图所示:
