MC9S08PA60 not in the CW10 list? No PA family.
1,463 次查看
timothycole
I am trying to get an MC9S08PA60 working. I have designed it into a new board. I just downloaded the CW for MCU, and installed, but when creating a new project, I cannot choose this micro. The "PA family" is not listed.
Thanks in advance,
Tim
标记 (1)
4 回复数
1,306 次查看
ZhangJennie
hi Timothy
I don't know which CW10 version you work with.
I suggest you use CW10.6+update2:
https://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=CW-MCU10&tid=CWH
You can download CW10.6 update2 directly here:
http://www.freescale.com/webapp/sps/site/overview.jsp?code=CW_UPDATES_MCU_10_6
after install, we can see see pa60 listed when creating a new project.
hope this helps!
Zhang Jun
this answer is for you. if it helps, please click on "Correct Answer" button. Thanks!
1,306 次查看
timothycole
Hi Zhang, Thank you for your reply. I feel better knowing that CW does provide for this chip, but now I need to figure out what I am missing. I tried the first link you provided. I downloaded the two main components (CW_MCU_10-6Update_1.0.0 & CW_MCU_10-6Update_2.0.0), but when I attempted to install them, I got a message that they were already installed. Maybe I should un-install everything, and start over? This software seems to be complex, as it appears to rely on many underlying components. Is there a single file install file, or method to get the latest version? Thank you for your help!  Tim
1,306 次查看
ZhangJennie
hi Timothy,
these two updates are for CW10.6 but not for other versions. what's CW version do you use? if you don't use CW10.6, please install CW10.6 ( CodeWarrior for Microcontrollers-Eclipse IDE|Freescale ) first then install updates
hope this helps!
Zhang Jun
1,306 次查看
timothycole
Hi Zhang, Thank you for your help. I un-installed Code Warrior, and started over using the links you provided. It is now installed.
Thanks again,
Tim
