I purchased the ColdFire M54455EVB and I was following the CodeWarrior for ColdFire Architectures V7.0 Quick Start guide when I clicked on the Project>Debug I get error message "Unable to use the plugin CCS_CF_Protocol_Plugin. It is licensed and a valid k
johnchan
I purchased the ColdFire M54455EVB and I was following the CodeWarrior for ColdFire Architectures V7.0 Quick Start guide when I clicked on the Project>Debug I get error message "Unable to use the plugin CCS_CF_Protocol_Plugin. It is licensed and a valid key was not found." How to resolve this error? I have installed CodeWarrior on PC running Windows 7 32-bit.
ZhangJennie
Hi John,
the license with the evaluation board is special edition license or evaluation license.
special license doesn't include full feature of CW.
when evaluation license gets expired, it doesn't support CW either.
I wonder you should use expired evaluation license or special edition license.
I suggest you contact nxp support to apply a new evaluation license to test your system, here is how to contact NXP support
How to submit a new question for NXP Support
if you want to go on using CW, please purchase it from this url:
CodeWarrior Suites (Bas, Stand, Pro)|NXP
Jennie Zhang
