I am not able to open "Software Licensing and Support" page to generate the license file
1,701件の閲覧回数
indiait
Hi Gorge,
I am starting separate discussion for the same issue as I am not able to reply to your earlier message. When I press ACTIONS tab to reply your earlier message, it is not showing any error but simultaneously no new page will appear for reply. Screen shot is attached for your information.
Regarding the initial issue (as per the subject line), when I am pressing the "Software Licensing and Support" tab, it just try to switch to new page (approaching link is pasted below) but finally it will land on same home page.
https://nxp.flexnetoperations.com/control/frse/login?email=Mb542Zm2oIAcs0qH9AALNMmpM26LUazK%2BR6jvAF...
Normally any clicks on this portal will not showing any error messages so it bit difficult for me to convey the same. Can I get your contact number or email ID for further level evaluation?
Ranjith Hegde
AMETEK India (Bangalore)
1,497件の閲覧回数
ZhangJennie
HI,
I just tested "Software Licensing and Support" page from my side. i didn't see any problem. see attached window.
I would suggest you test it with another browser.
if still can not solve your problem, because this related with your personal asset, I suggest you summit a case to NXP support team:
To submit your case into the new system, please follow below steps:
1) Go to http://www.nxp.com/support/sales-and-support:SUPPORTHOME.
2) On the bottom of the page under Submit New Issues, click Hardware & Software.
3) Register with your business email to access NXP technical online support.
4) A verification email will be sent to your account. Click the link embedded in that email to verify your access.
5) On the NXP online support page, select Contact Support from the top menu and click “submit a new case” to start the process.
can this help you?
Jennie Zhang
1,497件の閲覧回数
indiait
Hi Zhang,
I have tried "Software License and Support" tab in multiple system over IE11 and Google Chrome but no luck, finally opened Case 00069147.
Thanks a lot.
Regards.
