How to import this codeWarrior project to KDS3.2???
1,263 次查看
vigneshbalaji
Senior Contributor I
     I want to import a codeWarrior project to  Kinetis Design studio 3..2???How to do that? I have followed a user manual which I have attached in the thread.I am finding difficulty in the linking stage (stage 6).I have also attached a codeWarrior project.Can you help me to port from CW to KDS with respect to stage 6.
Original Attachment has been moved to: cw_to_kds.zip
1,046 次查看
TICS_Fiona
Hello VIGNESH
I attached the project which has been imported in KDS3.2, please check whether it works on your side. If not, please open the Project Properties, and check whether the Build Variable ‘MCUToolsBaseDir’ is consistent with the settings in your CodeWarrior folder.
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
