Hello Peter
A workaround is to copy the old workspace folder, then name the new folder and delete the “.metadata” subfolder under it.
The open CodeWarrior v10.5, and click on <File> menu->Switch Workspace to select the new folder.
But you need to drag the project or import in to the CodeWarrior Project view. The old project view is not kept.
Fiona Kuang
Technical Information & Commercial Support
