Difference between "fnop" and "nop" assembly instructions
7,519 次查看
xuedongyang
Hi, experts,
I am wondering what is the difference between "fnop" and "nop" assembly instructions. I am referring the document "VSPA-16SP ISA-v3.0 Instruction Set Manual for LA1224, Rev. A 10/2019". I see "fnop" and "nop" instructions in the document, but do not know the difference between them.
I tried both instructions in an assembly function I am working on. It seems to me both instructions work.
Xuedong Yang
7,475 次查看
yipingwang
Please refer to the attached document.
4 回复数
7,493 次查看
yipingwang
The fnop is always a full 64-bit instruction. It can be useful for aligning code.
With nop the compiler can choose either a 32-bit instruction or a 64-bit instruction.
The VSPA ISM revision that you are referring to (RevA) is quite old. In the later revisions of the ISM it was decided to replace all fnop to nop, and publish only nop in the document so as to give more flexibility to the compiler.
I believe Rev 0 is the VSPA  ISM latest revision available for LA1224. Do you have access to the latest rev?
7,488 次查看
xuedongyang
Thanks, Yiping, for the helpful answer.
No, I don't have latest version of LA1224 ISM, and don't know how to get it.
It would be great if you could guide me how to get the latest version of the document.
7,476 次查看
yipingwang
7,469 次查看
xuedongyang
Thank you very much for providing the latest document.
