Compiler Intermediate files
1,103 次查看
manishsangram
I need to see
1. The intermediate file post macro expansion (for C and CPP)
2. The intermediate assembly file
How can I get the same? Can't find any setting to generate these and cant find them in the Flash folder.
标记 (2)
719 次查看
BlackNight
In CodeWarrior there is a 'Preprocess' menu item to generate the preprocessing listing.
Otherwise for KDS see https://mcuoneclipse.com/2015/11/23/preprocessor-listing-for-gnu-gcc-with-gnu-arm-eclipse-plugins/
Erich
720 次查看
BlackNight
Erich
719 次查看
ZhangJennie
HI,
in c/asm source code, right click on the source and "Disassemble", you will see the list file generated. Please let me know if this is want you need?
Jennie Zhang
