Can not find sources under SDK 1.8
678 次查看
leventkarakaya
Hello
I started to design a custom board using T1024 processor. For this purpose, I am examining T1024rdb. We have several changes on the design of T1024rdb. I want to understand how to proceed code development.
I read info center pdf and several documentation and my plan is to modify T1024rdb sources to develop my custom u-boot and images. My custom image will contain several additional drivers to T1024rdb SDK. I installed Qoriq SDK v1.8 for t1024rdb-64b machine. Under the QorIQ-SDK-V1.8-20150619-yocto folder, there is a "sources" directory. I assume that all source codes, to be used for image build, should be under this folder. But, when I check the content, I run into empty git folders.
Where can I find the source codes of u-boot, image?  What do you think am I in the correct way to develop a custom image for my custom board?
source_code t1024rdb customization
568 次查看
yipingwang
Hello Levent Karakaya,
For u-boot:
1. Clean the build Cache:
$bitbake u-boot -c cleansstate
2. Get u-boot source code:
$bitbake u-boot -c patch
3. Go the source folder build_t1024rdb-64b_release/tmp/work/t1024rdb_64b-fsl-linux/u-boot-qoriq/2014.07+fslgit-r0/git/,
customize u-boot source code according to your requirement.
4. Comple u-boot
$ bitbake u-boot -c compile -f
5. Rebuild u-boot
$bitbake u-boot
6. Modify and rebuild source again, please go to 3.
For Linux Kernel:
1. Clean the Cache:
$ bitbake virtual/kernel -c cleansstate
2. Get Kernel source and Configure Linux Kernel:
$ bitbake virtual/kernel -c configure
3. Go to the source folder build_t1024rdb-64b_release/tmp/work/t1024rdb_64b-fsl-linux/linux-qoriq/3.12-r0/git/, modify the source code according to your requirement, and reconfigure Linux Kernel with the command "make ARCH=powerpc menuconfig".
4. Compile Linux Kernel
$ bitbake virtual/kernel -c compile -f
5. Build Linux Kernel
6. Modify and Reconfigure Linux Kernel again please go to 3.
Yiping
568 次查看
leventkarakaya
Thank you. Now it is clear.
