CW5.1 如何生成HEX或bin
CW5.1 如何生成HEX或bin
1,988 次查看
xwj
1. 我用codewarrior5.1 如何生成HEX 或BIN文件。
2. 用burner.exe 如何进行设置。
1,867 次查看
ZhangJennie
I suggest you refer Erich's article which includes how to use burner.exe to generate bin and hex file.
https://mcuoneclipse.com/2012/09/27/s-record-intel-hex-and-binary-files/
Can this help you?
Jennie Zhang
1,868 次查看
ZhangJennie
Can this help you?
Jennie Zhang
