關於IC電路和線寬問題
關於IC電路和線寬問題
1,009件の閲覧回数
chincs
Dear 您好:
我叫CCS
我想請問一下 關於FREESCALE IC 的問題,就是MMG3014NT1,MHT1006NT,MRF7S24250N這三顆IC的線路問題,
    我有參考datasheet上的資料,可是datasheet上沒有明確標註線寬的部分,想請問一下是否能提供這三顆IC在2450MHZ時的電路和線寬,謝謝!!
   以下附上這三顆IC的datasheet
     CCS
899件の閲覧回数
Wlodek_D_
Senior Contributor II
Dear chin cs,
Thank you for your inquiry, and please confirm if your question is still open.
If yes, then please describe what is your problem with devices you mentioned in your mail.
Please answer in English, as the machine translation returns ambiguous results.
What is your application? Is this a Microwave Oven or other device?
Is your question about microstrip lines dimensions on the PCB described in datasheet, or something else?
Your response will help in finding correct advice for you.
Wlodek_D.
