link error ... pls help
1,859 次查看
bingo23
Hi Everybody,
I'm new to codewarrior and I'm working on energy meter project. I got a reference code for this project and when I compile it I get the following error msg.
Link Error   : Undefined : "main"
Referenced from "_startup" in
Link failed.
What does this error msg mean and how do I solve it?
I'm using the codewarrior version 6.3. But the actual project was done in an older version. Could that be the reason for the error.
1,259 次查看
Lundin
Senior Contributor IV
It means that the linker can't find a function named main() in your program. "Startup" is the CW default code that gets executed after MCU reset, and it calls main().
1,260 次查看
Lundin
1,259 次查看
bingo23
Thanks for the quick reply.
Ive checked the code and the main() fn is defined. Then why is this error still occurring?
1,259 次查看
bingo23
oh sorry ... you were right. It was because the startup was calling Main() and the ref code was using main().
thanks a lot
