debug an elf file that is compile and build in another enveronnement different to codeworrior
2,941 次查看
zshel
dear all,
I use CodeWarrior 5.9 and I have an elf file that it is compiled and build with gnu gcc compiler,
I tray to debug this file with CodeWarrior 5.9 and I don't know how I do this, and I don't know how I load this file in the microcontroller which is mpc5604.
Can you help me please.
标签 (1)
6 回复数
1,658 次查看
J2MEJediMaster
Specialist I
In the CodeWarrior installation directory there should be a Help directory which has the CodeWarrior manuals. You want the Pro & Linux App Edition Targeting Manual.pdf file. In this manual, under the Working with the Debugger Chapter, the section Debugging Bareboard Software, subsection Debugging ELF Files Created by Other Tools, you should find the information you need.
---Tom
1,658 次查看
zshel
Hi Tom,
thank you for your reply, in the help directory, I don't find this manual .
in this directory, I have only this documents:
Assembler Reference.pdf
CodeWarrior CVS Plugin User's Guide.pdf
CodeWarrior IDE 5.9 User'sGuide.pdf
CodeWarrior IDE 5.9 Windows Automation Guide.pdf
CW Clear Case User's Guide.pdf
CW SourceSafe User's Guide.pdf
ICDPPNEXUS Quick Start Guide.pdf
MSL C Reference.pdf
MSL C++ Reference.pdf
PowerArchitecture Build Tools Reference.pdf
SPE Programming Interface Manual.pdf
Targeting MPC55XX Processors.pdf
So wich documents of them can help me
Thank you
1,658 次查看
zshel
Hi Tom,
I forget to say that I use CW 5.9,
thank you
1,658 次查看
J2MEJediMaster
Specialist I
The Targeting MPC55XX Processors.pdf manual should be similar to the one I suggested, whcih was for CodeWarrior for PA 8.8.
---Tom
1,658 次查看
CrasyCat
Specialist III
Hello
CodeWarrior for MPC55xx does not include an integrated debugger.
We are using external Third party debugger for this architecture.
Recommendation here is to use a third party debugging tool.
Included in CodeWarrior Special edition is the P&E Source Level Debugger.
All information on P&E debugger are available in the Targeting MPC55xx.pdf.
I am not sure how to load a third party .elf file in there, but you may find some assistance on P&E Forums (http://www.pemicro.com).
CrasyCat
1,658 次查看
zshel
Thank you for your reply
zshel
