converting float to char string
3,835 次查看
rickross
I am currently using Codewarrior 5. I want to write float numbers to Hyperterminal using the write command but so far I have been unsuccesful. I can however write characters. I tried using the gcvt() function to convert the float to a character string but codewarrior doesn't recognise it. Any ideas or examples or application notes I can use to write floats to Hyperterminal?
标记 (1)
987 次查看
CrasyCat
Specialist III
Hello
What about using printf?
sprintf can be used to convert a float to a string (array of char).
Several output format are possible. Please check ANSI C documentation to find out the one which suits best your needs.
CrasyCat
