add timestamp during compile
834 次查看
jfannon
I am looking for a way to include a timestamp in the code that I compile.  I want to assign an address in flash of say 4 bytes and put the date and time of compile into it automatically.(perhaps UTC time or some other format).  This way when I am looking at the firmware on a chip later I can determine when the code was compiled that is currently loaded.
Thank you for your help.
PS, I am programming a 9s08SH32 part if that makes any difference.
673 次查看
kef
Specialist I
There are predefined standard C string constants __DATE__ and __TIME__. Usage is like
const char date[] = __DATE__;
Unfortunately you can't change format of these or encode them to long int or other more compact form.
