USB HCS08/HCS12/CFV1 Multilink (Rev C or Later) - What about Rev A?
3,565件の閲覧回数
CarlFST60L_3rd
Hope this isnt to obvious that I have over looked somthing....
My Cylone pro has been sent back with a fault, so I have been leant a Rev A Multilink USB programmer from my supplier.
I have downloaded the latest drivers from PE Micro, I have searched the FAQ, here and google and cannot work out how to get Rev A working on codewarrior 5.9.0. The only option is Rev C in the connections manager. The "Port:" never has the device in the list, just says "Undetected. Disconnect........", but, device manager has it clearly listed, and the driver is 'current'. I have used a Rev C many times without any issues.
Thanks in advanced
Carl
2 返答(返信)
1,317件の閲覧回数
CarlFST60L_3rd
Does anyone have some ideas for me to try out?
I really need to debug some code using this Rev A Multilink USB programmer...
Message Edited by CarlFST60L_3rd on 2008-03-21 05:01 AM
1,317件の閲覧回数
J2MEJediMaster
Specialist I
Im thinking that this is a driver issue because clearly the port and software was working with the Rev C device, but not Rev A. Check out this link on the P&E Microcomputer Systems site here. I'm thinking that you have a USB 2.0 driver, which hasn't got a clue about a USB 1.1 device. I'd go their downloads page here and download their hardware interface drivers. Then do an install and see if that provides the proper driver for your Multilink Rev A.
