Text table values not located near each other in memory
821件の閲覧回数
ignisuti
I have the following list of text values defined in my code.
static char const * const daylight_savings_time_tbl[ TIME_DAYLIGHT_SAVINGS__CNT ] =    {    /* TIME_DAYLIGHT_SAVINGS__OFF  */ "Off",    /* TIME_DAYLIGHT_SAVINGS__ON  */ "On",    /* TIME_DAYLIGHT_SAVINGS__AUTO     */ "Auto"    };
Unfortunatly, these text values don't all show-up together in RAM (see image below). Is there another way I can declare this table?
It's rather critical to what I'm trying to accomplish. Because my function is handed many tables of strings like this one, I have it simply search for the NULL character and assume the start of the next string is the next character.
MCU Memory
737件の閲覧回数
ignisuti
Forgot to add this is with CodeWarrior 10.1 and I'm using a Coldfire MCF51CN128 MCU.
737件の閲覧回数
ignisuti
Okay, so I found that unchecking the following compiler setting fixed my problem.
To fix this issue, uncheck this value:  Project > Properties > C/C++ Build > Settings > Language Settings > Reuse Strings
If anyone has any other suggestions, please let me know.
