NEED DSP56805 flash.cfg for 56800E FLASH programmer
vianneyf
hello
i need the dsp56805_flash.cfg for flashing my DSP56F805 with Codewarrior USB TAP...
there are lot's of dsp56800 flash config file except my DSP
somebody can help me please to creat the flash config? or sending the file?
thank you very much
J2MEJediMaster
Specialist I
Here you go. It's from CW for DSC56800E v8.2.3. HTH.
---Tom
vincenzogiobbe
hello
i need the dspxxxx_flash.cfg for flashing my DSP56F827 with Codewarrior USB TAP...
thank you very much
vincenzo.giobbe@novatel.it
J2MEJediMaster
Specialist I
What version of CodeWarrior are you using? In the CodeWarrior IDE, go to Help > About FreescaleCodeWarrior > Installed Products for this information. I suspect that you might need to install a service pack.
---Tom
