Linker does not compress gaps between VLE functions like Reference Manual say
1,084件の閲覧回数
AndyMax
The "CodeWarrior Development Studio for
Power Architecture® Processors Build Tools Reference " says:
-func_align
     Specifies alignment of functions in executable code.
      Syntax
     -func_align 4 | 8 | 16 | 32 | 64 | 128
      Remarks
             The default alignment is 4. However, at an optimization level 4, the alignment changes to 16. If you are using -func_align 4 (or none) and if you are compiling for VLE, then the linker will compress gaps between VLE functions:
 • if those functions are not called by a Classic PPC function
 • the function has an alignment greater than 4.
       NOTE    Compression of the gaps will only happen on files compiled by the CodeWarrior compiler.
Questions:
1. Isn't there a contradiction here or how should this be understood?
"If you are using -func_align 4 (or none) and if you are compiling for VLE, then the linker will compress gaps between VLE functions:"
" • the function has an alignment greater than 4."
2. What is "Classic PPC function" ?
3. Why I still have gaps "00 00" between functions: I compile VLE code and "Function alignment"(Code Generation->EPPC Processor) in Codewarrior project settings is set to "4 Byte" (check attachments)?
994件の閲覧回数
AndyMax
FORCEFILES { "module.o" }
For some reason it gives the linker the right to forget about his promises. If you have same issue just remove your module name from it.
3 返答(返信)
995件の閲覧回数
AndyMax
1,056件の閲覧回数
AndyMax
UPD1: I created blank project and fill it with example functions, and this project no generate gaps between functions. I'm keeping play with this
1,076件の閲覧回数
AndyMax
... attachments ...
%3CLINGO-SUB%20id%3D%22lingo-sub-2163980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AF%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB%E3%81%AB%E6%9B%B8%E3%81%8B%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%ABVLE%E9%96%A2%E6%95%B0%E9%96%93%E3%81%AE%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%82%92%E5%9C%A7%E7%B8%AE%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163980%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E%E3%80%8CCodeWarrior%20Development%20Studio%20for%3C%2FSPAN%3E%20%3CSPAN%3EPower%20Architecture%20%C2%AE%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5%20%E3%83%93%E3%83%AB%E3%83%89%20%E3%83%84%E3%83%BC%E3%83%AB%20%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%80%8D%E3%81%AB%E3%81%AF%E6%AC%A1%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CFONT%20size%3D%224%22%3E%3CSTRONG%3E-func_align%3C%2FSTRONG%3E%3C%2FFONT%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E5%AE%9F%E8%A1%8C%E5%8F%AF%E8%83%BD%E3%82%B3%E3%83%BC%E3%83%89%E5%86%85%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%AE%E9%85%8D%E7%BD%AE%E3%82%92%E6%8C%87%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%E6%A7%8B%E6%96%87%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E-func_align%204%20%7C%208%20%7C%2016%20%7C%2032%20%7C%2064%20%7C%20128%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%3CSTRONG%3E%E5%82%99%E8%80%83%3C%2FSTRONG%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%E3%83%87%E3%83%95%E3%82%A9%E3%83%AB%E3%83%88%E3%81%AE%E9%85%8D%E7%BD%AE%E3%81%AF%204%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%9C%80%E9%81%A9%E5%8C%96%E3%83%AC%E3%83%99%E3%83%AB%204%20%E3%81%A7%E3%81%AF%E3%80%81%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%2016%20%E3%81%AB%E5%A4%89%E3%82%8F%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82-func_align%204%20(%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%AA%E3%81%97)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81VLE%20%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AF%20VLE%20%E9%96%A2%E6%95%B0%E9%96%93%E3%81%AE%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%82%92%E5%9C%A7%E7%B8%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%E2%80%A2%20%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%96%A2%E6%95%B0%E3%81%8CClassic%20PPC%E9%96%A2%E6%95%B0%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E5%A0%B4%E5%90%88%3C%2FDIV%3E%3CDIV%3E%E2%80%A2%20%E9%96%A2%E6%95%B0%E3%81%AE%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%204%20%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CDIV%20class%3D%22%22%3E%3CP%3E%3CSPAN%3E%3CSTRONG%3E%E6%B3%A8%3A%3C%2FSTRONG%3E%3C%2FSPAN%3E%3CSPAN%3E%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%AE%E5%9C%A7%E7%B8%AE%E3%81%AF%E3%80%81CodeWarrior%20%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%A9%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%95%E3%82%8C%E3%81%9F%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%AE%E3%81%BF%E8%A1%8C%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%20------------------------%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B3%AA%E5%95%8F%3A%3CBR%20%2F%3E%3CBR%20%2F%3E%201.%E3%81%93%E3%81%93%E3%81%AB%E7%9F%9B%E7%9B%BE%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%81%8B%E3%80%81%E3%81%9D%E3%82%8C%E3%81%A8%E3%82%82%E3%81%93%E3%82%8C%E3%82%92%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E7%90%86%E8%A7%A3%E3%81%99%E3%81%B9%E3%81%8D%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FSPAN%3E%3C%2FP%3E%3CDIV%3E%3CSPAN%3E%E3%80%8C-func_align%204%20(%E3%81%BE%E3%81%9F%E3%81%AF%E3%81%AA%E3%81%97)%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%E3%80%81VLE%20%E7%94%A8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AB%E3%83%BC%E3%81%AF%20VLE%20%E9%96%A2%E6%95%B0%E9%96%93%E3%81%AE%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%82%92%E5%9C%A7%E7%B8%AE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%80%8D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3CDIV%3E%E3%80%8C%E2%80%A2%20%E9%96%A2%E6%95%B0%E3%81%AE%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AF%204%20%E3%82%88%E3%82%8A%E5%A4%A7%E3%81%8D%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%E3%80%8D%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%3CBR%20%2F%3E2.%20%E3%80%8C%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AFPPC%E6%A9%9F%E8%83%BD%E3%80%8D%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%203.%20%E9%96%A2%E6%95%B0%E9%96%93%E3%81%AB%E3%81%BE%E3%81%A0%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%80%8C00%2000%E3%80%8D%E3%81%8C%E3%81%82%E3%82%8B%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82VLE%20%E3%82%B3%E3%83%BC%E3%83%89%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%97%E3%80%81Codewarrior%20%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E8%A8%AD%E5%AE%9A%E3%81%AE%E3%80%8C%E9%96%A2%E6%95%B0%E3%81%AE%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%80%8D(%E3%82%B3%E3%83%BC%E3%83%89%E7%94%9F%E6%88%90%20-%26gt%3B%20EPPC%20%E3%83%97%E3%83%AD%E3%82%BB%E3%83%83%E3%82%B5)%20%E3%81%8C%E3%80%8C4%20%E3%83%90%E3%82%A4%E3%83%88%E3%80%8D%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%20(%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84)%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164637%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSTRONG%3EFORCEFILES%20%7B%20%22module.o%22%7D%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E7%90%86%E7%94%B1%E3%81%A7%E3%80%81%E3%83%AA%E3%83%B3%E3%82%AF%E5%85%83%E3%81%AB%E7%B4%84%E6%9D%9F%E3%82%92%E5%BF%98%E3%82%8C%E3%82%8B%E6%A8%A9%E5%88%A9%E3%81%8C%E4%B8%8E%E3%81%88%E3%82%89%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E5%90%8C%E3%81%98%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E5%90%8D%E3%82%92%E5%89%8A%E9%99%A4%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2164073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2164073%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EUPD1%3A%20%E7%A9%BA%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%80%81%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E9%96%A2%E6%95%B0%E3%82%92%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%93%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%81%AF%E9%96%A2%E6%95%B0%E9%96%93%E3%81%AB%E3%82%AE%E3%83%A3%E3%83%83%E3%83%97%E3%81%AF%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E7%A7%81%E3%81%AF%E3%81%93%E3%82%8C%E3%81%A7%E9%81%8A%E3%82%93%E3%81%A7%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Linker%20does%20not%20compress%20gaps%20between%20VLE%20functions%20like%20Reference%20Manual%20say%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163992%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E...%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB...%3C%2FP%3E%3C%2FLINGO-BODY%3E
