I am using codewarrior 4.7 on 9s12xdp512 chip. I click on a bean to view open the Bean Inspector and get nothing. No warnings or reasons for the bean inspector not opening. Is this a laptop issue or a setting in codewarrior?
ソリューションへジャンプ
2,136件の閲覧回数
michaelgraham
I am having trouble getting my bean inspector to show settings.  Is this a settings problem or a laptop problem.  It has worked in the past but when I open up an old project when I click on a bean nothing will be displayed on screen and no indication of a problem is shown.
1,821件の閲覧回数
ZhangJennie
Hi Michael.
One of my customer met similar problem as yours, he found the Inspector window by moving slider. see attached video.
if this can not help you, please create a new project with wizard, can the new project works normal?
Jennie Zhang
3 返答(返信)
1,822件の閲覧回数
ZhangJennie
Hi Michael.
Jennie Zhang
1,821件の閲覧回数
michaelgraham
the problem must occured when I was using dual screens and the inspector got moved out of view when I switched back to a single monitor.  I opened up an old project and got the inspector in view and then opened up the project that had the missing bean inspector and the bean inspector showed up.  thanks for your help
1,821件の閲覧回数
ZhangJennie
You are welcome!
Jennie Zhang
