Hello Freeman
There's no option in Classic CodeWarrior v8.3 for 56800/E to generate the object files.
The command-line compiler can generate separate object files, the option for this switch is '-codegen'. But this is not available for the compiler plugin in CodeWarrior IDE. Such behavior is same with CodeWarrior for MPC56xx as well.
The new CodeWarrior v10.x for MCU also supports 56800E products. The compiler plugin in this IDE can generate separate object files.
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
Hope it helps!
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
