HELP!! Serial Communications MC13192-SARD board
1,835 次查看
krs1
Hi.
I'm trying to get serial communication working in Codewarrior for my MC13192 SARD board.  I was able to insert the AsynchroSerial bean into my project.  But not sure how to get it working, when I view it through hyperterminal it displays junk.
Can someone please help me figure out how to be able to do rs232 communications from my board to the PC?
Thanks!
326 次查看
stanish
It seems that the MCU transmits something to your PC since you see a junk at least.
I'd suspect the baudrate is differnet on MCU or PC side. I'd suggest you to double check RS232 communication settings on PC and MCU side (e.g Baudrate, parity, stop bits...). They must match otherwise received data are not interpreted correctly. Particular bean settings depend on the oscillator you are using (external vs. internal).
Message Edited by stanish on 2008-05-28 01:48 PM
