Creating .elf file license dependent?
1,004 次查看
JakobZimmerer
Hi guys,
I've got a problem with creating .elf files.
Couple of days ago I couldn't get a  repaired license so I contacted support.
First they gave me a 30 day license. With this license I was able to generate .elf files.
After they fixed the problem with my account I downloaded the repaired license.
Now I can't generate .elf files anymore.
I don't get any errormessage. I tried it with an old license for 128k. This time it said that my code is to big.
I'm using CodeWarrior IDE version 5.7.0
Build 2264
On a Coldfire-MCF5213
Can anybody tell me where I can look up this error or how to fix ist?
Thanks in advance!
Jakob
846 次查看
J2MEJediMaster
Specialist I
It sounds like there's still a problem with your license. Usually you get a code size limitation when you are using a Special Edition CodeWarrior license. I would check back with the licensing people on this.
---Tom
