Checking Memory Usage for MC56F3XX
1,267 次查看
Fortchio
I am using the MC56F346 device and the sdm pROM-xRAM target. How can I check my memory usage? I think I am unable to compile my code because I have ran out of ROM memory but need to confirm this....
All and any advice would be much appreciated...
Thanks in advance,
Steve
标记 (1)
993 次查看
J2MEJediMaster
Specialist I
Have you tried looking at the map file generated by the linker? More on the map file and settings panel used to generate it can be found in the MC56F8xxx/DSP5685x Family Targeting Manual. This is an Acrobat file. Targeting_56800E.pdf, that can be found in the Help folder of the CodeWarrior installation folder.
---Tom
