[CW5.2] I want to output a warning message to a file.
1,227 次查看
donggiyeom
-WOutFileOn command was able to output an error message.
However, I can not find an option to print a warning message to a file.
Please tell me.
标记 (2)
1,039 次查看
ZhangJennie
Hi donggi.
I just checked option -WOutFileOn, it can output warning but it has problem. see my attached testing video.
warning messages can be printed to EDITOUT but it must be after error messages.
I wonder this is the problem of option -WOutFileOn.
Unfortunately there is no other option can utilize this feature.
as a workaround, if you use CW IDE -  I advise doing Ctrl+C when the "Errors & Warning" message window is ACTIVE. Then just do Ctrl+P in a separate file to paste all the errors and warnings.
Jennie Zhang
