Hi again
Thanks for getting back to me.
I am using the kinetis as well; the k20. What a lot of grief, trying to get this to work with MQX!
Are they any examples you can share. I think as you have said, that getting this to work will be a nightmare... like almost all the Kinetis stuff. It might be worth it in the end, but the hardship and expense was not clearly understood on my part at least, and now facing this same thing with the flash that we found with MQX, PE and the BSP issues is going to be hard.
Robert
