CW SC - SC100 - How to analyse performance of the code on simulator
2,449 次查看
amol
I want to analyse my code in terms of memory usages, cycle count, etc. I am using CodeWarrior IDE for StarCore V5.7.0 (Trial Version).
I don't have a hardware and I am using SC100 simulator. The profiler is not working on the simulator.
Please suggest a solution.
Alban Edit: Please always include FSL Part Number in Message Subject line.
Message Edited by Alban on 2007-09-20 10:18 AM
711 次查看
CrasyCat
Specialist III
Hello
You can use the Runsim command line simulator to collect profiling information in simulation.
Please refer to {Install}\Help\PDF\Targeting StarCore.pdf, chapter "Debugger Communication Protocols", section "RUNSIM Command-Line Tool" -> "RUNSIM Profiling" for more info.
CrasyCat
