Hi everybody,
Currently we are using codewarrior 5.1 and mc9s12dg256 controller.
Our firmware have reach memory limits, so we are forced to use optimize for code size.
The problem is that we have to speed up some of the firmware routines.
We wonder if we can have a separate optimization for some routines. (optimize for code size for the whole firmware, but optimize for execution time for specific routines)
We have search CW documentation but we could not find anything.
We will appreciate any help
已解决! 转到解答。
Hi Eric,
By default the build tool chain for HC12 v5.1 used several optimizations.
The optimizations are defined for all project - for all project source files.
Now if for a file you want to disable some options, add other ones you can use the #pragma OPTION.
I recommend you to have a look in the \CWS12v5.1\Help\PDF\Compiler_HC12.pdf page 383.
Hope this will help.
Pascal
Freescale Technical Support
Hi Eric,
Pascal
